Home > General > engine system fault my dilemma
Zack17
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
having just spent £2500 on service /new belts & parking brake faults which included new rear discs etc , a week later the engine system fault showed up so back to local Indy who diagnosed faulty turbo/modulator replacement cost £1700 !! My dilemma is this is a 2008 2.7tdv6 so is it worth more expense or should I get rid ? Generally been a joy to own & drive & would love to keep ! mileage 111,000 . Any advise,comments/help much appreciated .
Post #592178 Sat Dec 21 2019 6:01pm
What fault code ?
Maybe stick some Wynn’s vvt cleaner in the tank.
Purple bottle
Post #592182 Sat Dec 21 2019 8:03pm
1richard1
Hi if you go for the repair you are upto half the valve of the motor, depending what else you have paid to be done? the choice is a hobson's choice, pay for the repair do you know the history, are you prepared to fork out more money to keep it on the road in the future.
By the sounds of it you are questioning the costs of keeping it going for yourself at that point id go for something maybe more reliable and cheaper to repair.
As all on here know these are nice motors when working well but when they go wrong deep pockets are needed, i've not long bought an older one but when i start to add what i've spent on bits and bobs already, i am in the realms of a nearly new motor but no where near the class of motor or ability.
If mine starts to get expensive to keep it going i will chalk it it to a good experience and back to more reliable/inexpensive motoring.
Saying that the next motor will be 1977 pontiac fire bird what i save on repairs it will use in fuel consumption, age is just number but im still a big kid at heart Whistle
Post #592187 Sat Dec 21 2019 10:43pm
Oldandconfused
Not knowing exactly what the faults are, it's difficult to properly advise. That being said, I'm sure there was a repair kit for the turbo actuator that can be fitted in situe. Have a search on the Disco3 forum, there are owners on there who have had success with lubricating it, although I cant remember if it was a permanent fix.
Post #592188 Sun Dec 22 2019 12:46am
Have a look at this, may be what Oldandconfused is thinking of.
https://disco3.co.uk/gallery/albums/userpi..._TOPIx.pdf
Post #592189 Sun Dec 22 2019 1:00am
Zack17
Thanks for all advise try & go in tomorrow to establish codes , hoping that Bodsy will call in when he`s up this area & be able help/advise . Think a gearbox flush is about all left to do !!
Probably will spend on & keep as wife loves driving it !!
Post #592218 Sun Dec 22 2019 2:53pm
Godders
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I had the turbo actuator replaced about 12 months ago and it cost me about 1,600 euros at a JLR garage in
france.I am of the belief that whilst I understand your frustration, it really is better the devil you know with your car. You will lose big time on selling it if you don't do the repair, and give someone else the benefit of all the work done if you get it repaired and then sell it.
Good luck with whatever you decide. Thumbs Up Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #592295 Mon Dec 23 2019 5:53pm
knwatkins
I completely agree with the above. I also had a decision to make which meant spending 50% of the vehicles value to fix it. It was definitely the right decision for me.
As Godders says, it's "better the devil you know".
You could sell it cheap, buy another one and have exactly the same issue in 6 months time. At least if you get it fixed, you've ruled out the that issue occuring again. Well, in the sort term at least Whistle
At the end of the day though, it's whatever you think is best. Kev
Post #592299 Mon Dec 23 2019 7:02pm
Oldandconfused
I think thats for the 3.0ltr 2010-13my Col, OP's is a 2.7.
OP could really do with joining the Disco3 forum and putting aside an evening to search for turbo+actuator+seized. There are a lot of threads regarding stuck actuators and freeing them off e.g;
https://www.disco3.co.uk/forum/help-turbo-...r%2Bseized
There are so many threads there about the turbo that you could be there all day and fault codes would narrow it down on a search as many members have posted their codes. If I have a spare day, I will see if I can find something about a revised actuatot\r part for the 2.7
Post #592319 Tue Dec 24 2019 9:54am
Zeoman
Scotland 2006 Range Rover Sport TDV6 HSE Siberian Silver
Is the vvt cleaner the same as turbo cleaner? Been into Halfords and looked on Wynns website and can’t find it.
Post #592333 Tue Dec 24 2019 3:25pm
Zack17
Engine Restricted Performance -Diag £1686 inc vat
[img]http://www.rrsport.co.uk/gallery/albums/userpics/22460/Scan0016.pdf[/img]
Update --P132B-22 Turbo/Supercharger Boost Control A performance, signal amplitude Maximum.
P138E-22 Turbocharger boost control position sensor A min/max Stop performance, signal amplitude maximum
Hope this makes sense , please comment .Cheers
they have also offered gearbox flush for £170 ?
Post #592529 Mon Dec 30 2019 2:02pm
Zack17
Ps Sport went into limp-mode this morning within 1/4 mile of home so guess it needs tlc very soon !!
Post #592530 Mon Dec 30 2019 2:05pm
Check to see if actuator is stiff thru passenger wheel arch
You can try oiling it from the outside if you wish.
Or use Wynn’s vvt cleaner to clean soot off inside.
Post #592538 Mon Dec 30 2019 5:04pm
Oldandconfused
Bit more light reading;
https://www.disco3.co.uk/forum/d3-turbo-ac...vice%2Bkit
Post #592543 Mon Dec 30 2019 6:34pm
Zack17
Well all mended now & had gearbox flush done , its like driving a new car !! costly yes but life`s to short ! well that's my excuse !!
Post #593471 Sat Jan 18 2020 2:26pm
