![]() | Home > General (L494) > 18, 19 SVR owners, question |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi guys,
Wonder if mine is fault, carnt here any difference switching the exhaust off and on at tick over? |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 248 ![]() ![]() |
My understanding is the valve is open at cold start then closes for comfort mode. When dynamic mode is selected it opens or partialllh opens. Upon the higher revs it’s noticable. |
I would have thought the same. At cold start, driving etc, switching on and off apears to make no difference at all. Guess its faulty. |
The 18’s and 19’s are quieter than previous SVR’s but my 19 is loud enough for me. You’re only going to notice it at higher revs. |
Hi ya,
Q86ARR Member Since: 07 Dec 2019 Location: Channel Islands Posts: 4 ![]() |
Have a look down the tailpipes
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
The best way to test it is to put the exhaust on then use the paddles which you will then get the crackles and pops with the exhaust off this will not happen. SVR 2018 in Santorini Black. |
I guess I just down shift with paddles etc? |
So today on the way home from work, dynamic mode, sport, exhaust on. I drove with padels, even going down the gears coming to junctions and from inside, I never herd any pops etc. What's an easy way to force them? Can you only hear them with window open? I looked down the exhaust yesterday and ignition off, both sides flaps closed. Ignition on they where both open. |
Watch from 3:30 in link
Strange big, mine makes a hell of a rackett with the paddles and exhaust on , i don't think i even put it in dynamic either. In fact i don't even use the paddles anymore as it's just too loud. SVR 2018 in Santorini Black. |
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 ![]() ![]() |
Definitely get it check as it may well be a fault with the active exhaust switch.
All petrol engined cars built after July 2018 in the EU markets have to have a GPF (gasoline particulate filter) and this has quietened down SVR’s considerably 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
