![]() | Home > Technical > Gear lever surround trim clips. |
Ians63 Member Since: 03 Sep 2019 Location: NE Scotland Posts: 20 ![]() ![]() ![]() |
Looking to source trim clips for the gear lever surround. Mine is just sat there rattling about loose! RRS 2006
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Probably be in the console |
No joy with the magnetic fishing - some scary sticky furry things in there though!
I'm sure you will find several £1 coins too |
Found a pair of long-reach needle nose pliers in the plastic ECU box on my car - that was handy, I'd been meaning to buy a set of those for ages.. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If you mean these clips unfortunately they don't appear to list them in the parts list separately from the whole surround bit, might have to be breaker's yard job.
Yes that is the clips I need - thanks for the info. RRS 2006
