Home > Technical > Gear lever surround trim clips.
Ians63
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Looking to source trim clips for the gear lever surround. Mine is just sat there rattling about loose! RRS 2006
2.7 TDV6
Zermatt Silver
Post #591050 Tue Nov 26 2019 8:32pm
Probably be in the console Laughing
Get a magnet on a wire and go fishing
Post #591054 Tue Nov 26 2019 9:36pm
Ians63
No joy with the magnetic fishing - some scary sticky furry things in there though!
These are the clips I need for the gear surround trim
 RRS 2006
2.7 TDV6
Zermatt Silver
Post #591221 Fri Nov 29 2019 9:03pm
Brit Plumber
Go extreme, seats out, console out, carpets out, retrieve clips, missing fuses, fuse pliers, £19.80 in loose change, mouldy apple, 1/2 a Burger King, clean disinfect and rebuild! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #591301 Sun Dec 01 2019 1:01pm
I'm sure you will find several £1 coins too
Post #591305 Sun Dec 01 2019 1:53pm
aaronjb
Found a pair of long-reach needle nose pliers in the plastic ECU box on my car - that was handy, I'd been meaning to buy a set of those for ages.. Laughing
Are these the clips? https://www.brit-car.co.uk/product.php/117...very_3___4
Or these? https://www.brit-car.co.uk/product.php/122...over_sport
Choices there - also available on eBay at a huge mark-up.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #591341 Mon Dec 02 2019 9:53am
If you mean these clips unfortunately they don't appear to list them in the parts list separately from the whole surround bit, might have to be breaker's yard job.
Post #591350 Mon Dec 02 2019 11:26am
Ians63
Yes that is the clips I need - thanks for the info. RRS 2006
2.7 TDV6
Zermatt Silver
Post #591358 Mon Dec 02 2019 12:49pm
