Home > Technical > Suspension issue £3k spent so far - RRS HSE 3.0 2009 |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 |
Hi Guys,
Wed Nov 20 2019 8:33am |
Thank you mate. It does sound like a leak somewhere doesn't it.
Thu Nov 21 2019 9:16am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
If you change from a Hitachi to AMK you need to change the relay and do a CCF update. 2019 5.0 SC SVA (Current)
Thu Nov 21 2019 9:44am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Is it every morning the front is lowering? And on both sides? Kev
Thu Nov 21 2019 6:39pm |
Hard to tell really because I have yet to park it on a totally flat surface.
Thu Nov 21 2019 7:06pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Switch to the suspension screen from startup. If one of the height sensors is playing up, you will see the wheel move up and down on the display. It might be worth getting the height sensors calibrated, as if they have been replaced and not setup properly, then the car will not sit correctly.
Thu Nov 21 2019 9:24pm |
Thanks Mate,
Thu Nov 21 2019 11:03pm |
Yep, once you know what you are listening for, you can hear it inside the car, but, it's obviously clearer outside.
Sat Nov 23 2019 3:03pm |
Ok so parked up last night. Drivers side on the kerb but across a driveway so not level.
Sun Nov 24 2019 1:06am |
OK, if i read that correctly, it looks like the drivers side front has dropped the most overnight, but that it has risen correctly when you started it in the morning. So given that you have had the front air struts replaced recently, I would be checking to see it the air line into the top of the strut is leaking.
Sun Nov 24 2019 9:37am |
It appears that that may have been the issue.
Sat Jan 11 2020 6:18pm |
