![]() | Home > Technical > Suspension issue £3k spent so far - RRS HSE 3.0 2009 |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 ![]() ![]() ![]() |
Hi Guys,
Thank you mate. It does sound like a leak somewhere doesn't it.
If you change from a Hitachi to AMK you need to change the relay and do a CCF update. 2019 5.0 SC SVA (Current)
Is it every morning the front is lowering? And on both sides? Kev
Hard to tell really because I have yet to park it on a totally flat surface.
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Switch to the suspension screen from startup. If one of the height sensors is playing up, you will see the wheel move up and down on the display. It might be worth getting the height sensors calibrated, as if they have been replaced and not setup properly, then the car will not sit correctly.
Thanks Mate,
Yep, once you know what you are listening for, you can hear it inside the car, but, it's obviously clearer outside.
Ok so parked up last night. Drivers side on the kerb but across a driveway so not level.
OK, if i read that correctly, it looks like the drivers side front has dropped the most overnight, but that it has risen correctly when you started it in the morning. So given that you have had the front air struts replaced recently, I would be checking to see it the air line into the top of the strut is leaking.
It appears that that may have been the issue.
