Home > Technical > Changing RHS inlet manifold 2012 3l SDV6 RRS
mdsparky
Hi Guys
Unfortunately I have the great pleasure of doing my inlet manifold due to leakage
My question is do i need to remove the EGR to get the fuel rail off? I'm really struggling to get to the bolt heads
Would be great if anyone can point me to a how to or youtube vid on this, I'm reasonably competant with a spanner but its a right tw4t of a job
TIA
Post #590462 Fri Nov 15 2019 6:06pm
Disco_Mikey
No, but if you unbolt the upper 3 bolts, it can be manipulated out the way Thumbs Up
Post #590467 Fri Nov 15 2019 7:05pm
mdsparky
Thanks Disco_Mikey, I did
Dont suppose you know if there are any bolts under the timing cover?
Post #590502 Sat Nov 16 2019 6:24pm
Disco_Mikey
No RH bolts under the cover, but the cover needs pulled forward to allow removal Thumbs Up
Post #590505 Sat Nov 16 2019 9:37pm
