![]() | Home > Maintenance & Modifications > Squealing rear breaks |
TonyMeg Member Since: 10 Feb 2007 Location: North East Posts: 128 ![]() ![]() ![]() |
Anyone else having problems with there rear break shoes ?? Had ours serviced last month ( 06 HSE with 10,500 miles on the clock ) & ever since we got it back the back breaks have sounded like an old tranny van.. Been to the dealers to book it back in today & the lad out of the work shop told me theres been a few in & LR have an updated part to solve it.. Wonder if it will be a warranty job then?? |
I don't believe pads and discs are covered under warranty, but the "permanent" parts of the braking system should be - if that's where the problem lies |
Thanks S & what you still doing here?? No sines of little legs yet?? |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
With 10.5k on the clock, I'd say you're being optimistic in the extreme with this one Tony. Haven't you got a mate who can quickly whip the pads off and coat the backs with high temperature copper grease? May cure it and save a fortune, worth a try! Good Luck. ![]() |
jk516696 Member Since: 15 Mar 2006 Location: uk Posts: 17 ![]() ![]() |
i've got the same noise
zulfi Member Since: 23 Feb 2007 Location: leeds Posts: 2 ![]() ![]() |
i have the same rear squeky brakes, on my ranger rover sport 2006. i have only done 11k miles, it is in with the dealer next week, so hopefully the can resolve the problem. |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
I've got a squealing park brake too. But I will leave it until it goes to be serviced next month.
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
This TSB (# LS206-001 here in North America) may apply, although it is very old - issued in December 2005 - and may not cover your VIN#:
Just got mine back from the dealers all sorted now & it was a warranty job too result |
Actually, when I purchased the car I was instructed that the electronic parking brake can be used as an emergency brake if the main ones should ever fail. You can apparently modulate how hard you brake with the e-brake by pulling on the center console lever with more or less "gusto"... |
They show you how to use the EPB in an emergency in the Level 1 course (at least my instructor did, I presume they follow a set curriculum wherever you take it)... only for use in emergencies though. |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
I've used it - just to see how it works - its very dramatic to say the least |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Ive tried the EPB while travelling at 30 mph, it is very sharp and noisy.Wouldnt want to try it at 70
Me too Envoy. Slam it in park and walk away. The EPB is hard work, occasional use only to prevent seizure! Lazy bast ![]() ![]() |
