Home > In Car Electronics > Dreaded parking sensors
Get's a bit confusing there are so many different numbers but LR024299 appears to be the one shown for the RRS2 mirror not sure if it's the wading one though.
How about these? half way down page.
https://www.powerfuluk.com/catalogsearch/result?q=sensor
Post #587787 Mon Sep 30 2019 8:49am
Brit Plumber
This is quite confusing really, PowerfullUk say that you can retrofit the face lift sport ones into the pre face lift usually but occasionally that doesn’t work.
I’m glad I just bought like for like and used the engineering number to search. I also see that they are the same as Ford sensors and if you ebay the Eng Part No. I mentioned, you get them on Fiestas and Focus’s.
Typically I have a PDC issue this morning on the front. Permanently on despite being wiped over. Pressing on the cover of the front right one stoped it. I shall see if it persists. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587792 Mon Sep 30 2019 10:58am
