Home > Technical > Inlet Manifold Failure - My sport is doomed!
derekmines
So either I've annoyed someone in a former life or I truly am the unluckiest man on earth as before I have even paid the invoice for the EPB issue that I had last week, within 100 miles of getting the car back on the road
Big Red warning light - reduced performance message
Code reader shows P006a code
Popped the engine cover off this morning and did a visual inspection, easily found a horizontal crack in the passenger side (LHS) plastic intake manifold - googling reveals it to be a known issue on the early 3.0 cars
Other than sharing my woes, I'm posting here to ask 3 questions..
1) Are aftermarket inlet manifolds (LR105956) a false economy (they're around £150 cheaper and..... big bills!)
2) Do I need the full injector refit kits (LR017437 x 2 and LR017438 x1) or can I just use new copper washers and reuse everything else - again over £200 saving which would be pretty handy!
3) Are those part codes correct and is there anything else I need?
Post #587438 Tue Sep 24 2019 10:36am
You have my sympathy. My 2012 3.0SDV6 did this a few weeks ago. Ended up getting both replaced on the basis that the manifold itself is the cheap bit of the job. Labour is the biggest bit by far. £1200 later... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #587455 Tue Sep 24 2019 3:35pm
derekmines
I wouldn't mind so much but since May (<5k miles) I've had suspension compressor failure, EPB seize on, stranding me in a car park until 4am and now this... If my total repair bills are less than £2200 I'll be very surprised.
Still, the only consolation I have is that I bought right at the bottom price in the market knowing that these things do happen and at least once fixed I will hopefully be good for many years.
You've got me wondering about doing the other manifold as a preventative measure now!
Post #587459 Tue Sep 24 2019 3:59pm
My view was that if you're stripping a lot of stuff off the top of the engine anyway, go the whole hog and do both. If one's gone, the other might do the same. Total bill for two separate manifold changes is likely to be more than twice the price of doing both together.
If you bought one "cheap" then you're possibly expected to have found one that is a little less well looked after. The EPB sticking on, for example, might be because the previous owner never used it, or it might be that the thing was only "change the oil and top up the screen wash" serviced.
Compressor failure isn't uncommon and might point to other issues - a small leak meaning the compressor is running a lot of the time leading to premature failure.
Getting one "right" and then enjoying it, is a nice feeling. My old TDV8 had a load of issues but once I sorted it (and changed to an indy for servicing and other work), it went on to 175k+ miles with me. It's still going, bought by a chap in the village. If he looks after it, it'll do 250k easily. I've already told him that if he wants to sell it (unless it's died! Whistle ), then give me first refusal. I never should have sold it really but couldn't justify having two RRS on the drive...I think I will try harder to do so next time Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #587460 Tue Sep 24 2019 5:05pm
Disco_Mikey
Never had a replacement genuine manifold split
That said, our Britpart rep also said they have never had one of their own brand replacements sent back under warranty...
I only replace the copper washers, never had an issue
Post #587464 Tue Sep 24 2019 6:20pm
knwatkins
If it makes you feel any better Derek, I recently added up how much I've spent on mine over the past 12 months - £9341.32 Shocked I am trying to latch on to the same view as you though - hopefully good for the next few years Whistle Kev
Post #587476 Tue Sep 24 2019 7:38pm
derekmines
Probably something in what you say there, although the PO had allegedly serviced the car, he sold it just as the big belt service was due (another reason I got it cheap) and it turns out that the "new" EPB module that he'd had fitted a few months before sale was actually a recon unit and because he didn't change discs, pads, shoes etc at the same time it failed on me not long after!
The compressor was just bad luck I think, not sure the car had ever been offroad before and it certainly hadn't towed, both of which I do fairly regularly, I guess the extra stress caused the failure!
Still, I'm lucky to have a good friend who's a mechanic so most of these failures can be rectified fairly quickly and I'm hoping for a trouble free winter once this latest malady is cured!
Post #587483 Tue Sep 24 2019 8:52pm
aaronjb
I don't know about Derek, but that makes me feel much better! Laughing
derekmines wrote:
Still, I'm lucky to have a good friend who's a mechanic so...
He'll be a really good friend after a few RRS repair bills! Wink Joking aside, it does sound like you've already changed the big things - apart from the intake manifolds! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #587497 Wed Sep 25 2019 6:57am
derekmines
Dare I ask what failed to generate that level of cost..... slightly scared now lol
Post #587500 Wed Sep 25 2019 7:38am
knwatkins
Here's a breakdown. Not all costs are a result of failure. The costs relate to service items, minor modifications and improvements. The biggest cost was when my engine spun a bearing.
Sept 2018 - Sept 2019
Bodywork inc wheel refurb £400.00
Interior Touch Ups £150.00
Spray Paint (Door Handles) £12.49
Spray Paint (Scuttle Panel) £12.20
Wheel Centre Caps £5.89
Interior Mats £40.00
Smoked Side Repeaters £10.00
Engine Oil (12 litres) Castrol C1 £101.23
2 x Mann Oil Filters £11.98
Air Filter £3.90
Fuel Filter £15.48
Diff Oil (0.6 litres + 1.1 litres) £4.37
Gearbox Fluid (20 litre Flush) £68.00
Hydraulic Anti-Roll Bar Filter £25.00
Hydraulic Anti-Roll Bar Fluid (2 litres) £13.60
Wiper Blades £24.55
Cabin Filter £9.34
Transfer Box Fluid & Plug £30.31
Spare Wheel Anti-Theft Plate £71.99
Door Release Cable £8.24
Nearside Front Door Latch (used) £25.00
Offside Rear Door Latch (used) £20.00
Front Nearside Door Windown Seal £46.00
Side Steps £110.00
Brembo Brake Discs, Pads & Wear Sensor (Front) £183.82
Bearmach Front Lower Arms £156.60
Lower Arm Bolt Kit £35.99
Bearmach Front Nearside ARB Link £8.23
ARB Bushes £25.02
4 Wheel Alignment £78.00
Stabilis Tailgate Struts £39.00
Fuel Filter Housing £40.00
Timing Belt Kit £67.48
Remote Park Heat Kit £126.96
Dunlop Struts All Round £689.02
Dunlop Air Compressor £305.00
Tailgate Latch Trim £6.06
GKN Rear Propshaft £239.99
Pirelli Tyre £146.20
Power steeting fluid (2 litres) £13.60
Brembo Brake Discs and Pads (Rear) £120.40
Brake Fluid 1 litre £8.96
20 x wheel nuts £31.75
Engine Rebuild inc 3 x replacement used injectors, block and crank £5,800.00
Total: £9,341.62 Kev
Post #587504 Wed Sep 25 2019 8:28am
derekmines
I really am doomed...
Got the car back from having a nice new inlet manifold together with genuine injector reuse kits and EGR gasket etc....
Now I appear to have some kind of small diesel leak to the lower end of the manifold somewhere (can't see where) as I've continual grey smoke, a strong diesel smell and rainbows when I park in wet spaces!
Honestly.... what next!?
Post #587998 Fri Oct 04 2019 7:32am
derekmines
What next turns out to be the suspected failure of the other side inlet manifold..... booked in to the local mechanic tomorrow to confirm but the symptoms are exactly the same as the first time round.
Ho hum, I'd had a few months without a big bill so was probably overdue lol
Post #607755 Tue Dec 22 2020 11:34am
