Home > Maintenance & Modifications > Jacked up - slightly concerned
BigPig
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Had the RRS in today to have the wheels balanced but noticed it was jacked up from points other than the approved ones. I don’t profess to know anything about this topic but the car suspension was not lowered first and the rear left wheel was still touching the floor whilst the other 3 weren’t. I was always told to lower the suspension first and to jack from the points by the side rails....
Post #586384 Thu Sep 05 2019 7:43am
Lots of tyre places will jack off the suspension arms rather than the chassis points. Done correctly, it's fine to do so. It has the benefit of only needing to jack the thing up a couple of inches to get the tyre clear of the ground. 2012 SDV6 - it's missing a couple of cylinders
Post #586385 Thu Sep 05 2019 8:01am
Bardley
As long as the jack wasn't sited on floor pans etc. and was lifted on the suspension components in the correct place, then it should be fine.
Having wheels still touching the ground sometimes confuses the system, but a restart usually sorts it out. Lowering suspension before jacking is not necessary. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #586386 Thu Sep 05 2019 8:02am
Never lowered suspension before jacking up vehicle, and always use low profile jack under wishbone arms, just make sure they haven't jacked on the compressor on the n/s/r either, have seen clowns do that.
col
Post #586389 Thu Sep 05 2019 8:36am
flydive
Re: Jacked up - slightly concerned
The manual says to set it to off-road '08 RRS TDV8
Post #586391 Thu Sep 05 2019 10:46am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Correct Flydive. And open one door.
Always Use the original jack points, RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #586400 Thu Sep 05 2019 1:53pm
I think the manual says to jack from off road height as they are writing for someone using the weak little supplied jack. You don't want to be lifting it any further than you have to on one of those!
When I jack mine with my trolley jack, I generally use the chassis points with a jack adaptor, jacking from normal height as it's easy with a decent trolley jack. 2012 SDV6 - it's missing a couple of cylinders
Post #586410 Thu Sep 05 2019 5:26pm
flydive
Yes, but why would you want to lift those extra 5 cm by "hand" when you can have the car to do it? '08 RRS TDV8
Post #586411 Thu Sep 05 2019 5:50pm
Because with my trolley jack it's easy and no real effort to do. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #586413 Thu Sep 05 2019 6:08pm
flydive
Well, then you could put the car in access mode, to have more fun Wink '08 RRS TDV8
Post #586417 Thu Sep 05 2019 6:14pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
Isn't the issue how the air suspension behaves? I always put to off road height and left the tailgate open. I thought that this stopped the air suspension from trying to adjust itself (i.e. lowering while lifted by the jack).
Post #586441 Fri Sep 06 2019 9:12am
DrRob
Much easier to use a trolley jack under suspension as suggested above. 2 pump, wheel off. Job done. Visitor from fullfatrr.com
Post #586446 Fri Sep 06 2019 3:08pm
flydive
You can even have the car lift the wheel by itself Wink
 '08 RRS TDV8
Post #586447 Fri Sep 06 2019 3:27pm
Tyrefitter
I usually lift all 4 wheels at the same time Laughing Laughing
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #586449 Fri Sep 06 2019 4:49pm
N60613
Bosnia Herzegovina
this is how i lift mine. normal height selected.
 RR 2012 4.4 TDV8
Post #586478 Sat Sep 07 2019 7:54am
