![]() | Home > Technical > parking aid |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
2 wires from the front of the car to the rear ? |
Pull the brown and black wires (pin 1 and 2) from Connector 1457 (module connector) and connect in 2 lengths of wire to the new front loom connector 2278 pin 1 & 3 (assuming that the front loom is new as stated in the first post). 2019 5.0 SC SVA (Current)
Col, is that the 2010 MY location diagram? 2005 to 2009 is likely different. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
I remembered I had access to some diagrams at work and I think the wiring diagrams shown previously are later diagrams. The 2008 diagram I have access to shows 3 wires to each sensor from the module whereas the later version has 2 common wires from the module which then splits between the 4 sensors.
The failure mode (of only certain sensors grenading) only really makes sense if the wiring diagram matches yours - assuming it's a short; with the commoned up feeds in the later wiring, you'd expect them all to pop at the same time.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Hopefully the OP can confirm what wiring diagram is what he has, it should be the one I posted but the diagrams have been wrong in the past. If it’s the 2 middle ones blowing, it’s a bit odd as they are almost 2 separate circuits.
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Sorry, my bad - luckily you have plenty of diagrams now ![]() ![]() |
No problem mate, we just need the OP to confirm the correct diagram. 2019 5.0 SC SVA (Current)
john.m Member Since: 27 Feb 2019 Location: Boness Posts: 11 ![]() ![]() ![]() |
Well I have fitted the rear original sensors to the front. Fitted more replacements to the rear to see what happens. I ordered 4 which went missing, Seller resent another 4 then the originals turned up. (Lucky me) so still have spare. So far all good Will update in a few days, They never last longer than that. 2008 range rover sport 2.7 hse |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Not really sure Chris, as appears to show same illustration for both models. Cheers Col |
The 2005 to 2009 diagram I have access to shows power to each sensor direct from the module rather than a single feed split between the 4 sensors. That will make a difference when fault finding. 2019 5.0 SC SVA (Current)
A wee update and a good lesson to learn.
If you have no luck with a refund, use the eBay dispute route, were the OEM sensors much more expensive? 2019 5.0 SC SVA (Current)
I paid £124.50 for the four. I was lucky as a local garage had a set ordered for someone else who never came back. Worth every penny.
