Home > Technical > parking aid |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
2 wires from the front of the car to the rear ? |
Tue Sep 10 2019 11:30am |
Pull the brown and black wires (pin 1 and 2) from Connector 1457 (module connector) and connect in 2 lengths of wire to the new front loom connector 2278 pin 1 & 3 (assuming that the front loom is new as stated in the first post). 2019 5.0 SC SVA (Current)
Tue Sep 10 2019 12:37pm |
Col, is that the 2010 MY location diagram? 2005 to 2009 is likely different. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Tue Sep 10 2019 12:42pm |
I remembered I had access to some diagrams at work and I think the wiring diagrams shown previously are later diagrams. The 2008 diagram I have access to shows 3 wires to each sensor from the module whereas the later version has 2 common wires from the module which then splits between the 4 sensors.
Tue Sep 10 2019 1:02pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
The failure mode (of only certain sensors grenading) only really makes sense if the wiring diagram matches yours - assuming it's a short; with the commoned up feeds in the later wiring, you'd expect them all to pop at the same time.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Tue Sep 10 2019 1:42pm |
Hopefully the OP can confirm what wiring diagram is what he has, it should be the one I posted but the diagrams have been wrong in the past. If it’s the 2 middle ones blowing, it’s a bit odd as they are almost 2 separate circuits.
Tue Sep 10 2019 1:52pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Sorry, my bad - luckily you have plenty of diagrams now |
Tue Sep 10 2019 5:42pm |
No problem mate, we just need the OP to confirm the correct diagram. 2019 5.0 SC SVA (Current)
Tue Sep 10 2019 5:58pm |
john.m Member Since: 27 Feb 2019 Location: Boness Posts: 11 |
Well I have fitted the rear original sensors to the front. Fitted more replacements to the rear to see what happens. I ordered 4 which went missing, Seller resent another 4 then the originals turned up. (Lucky me) so still have spare. So far all good Will update in a few days, They never last longer than that. 2008 range rover sport 2.7 hse |
Tue Sep 10 2019 8:37pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4972 |
Not really sure Chris, as appears to show same illustration for both models. Cheers Col |
Wed Sep 11 2019 5:52am |
The 2005 to 2009 diagram I have access to shows power to each sensor direct from the module rather than a single feed split between the 4 sensors. That will make a difference when fault finding. 2019 5.0 SC SVA (Current)
Wed Sep 11 2019 6:09am |
A wee update and a good lesson to learn.
Mon Sep 16 2019 8:39pm |
If you have no luck with a refund, use the eBay dispute route, were the OEM sensors much more expensive? 2019 5.0 SC SVA (Current)
Mon Sep 16 2019 9:15pm |
I paid £124.50 for the four. I was lucky as a local garage had a set ordered for someone else who never came back. Worth every penny.
Wed Sep 18 2019 8:10pm |
