![]() | Home > General (L494) > Another crank failure |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Tim McKnight is far closer https://www.alltrack4x4.com/ Joined the X5 45e club
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 251 ![]() ![]() |
My wife runs a Merc SLK which is serviced by Prestige Car Services in Horndean who have an excellent reputation for MB repairs and talking to Ollie the owner about my RRS he told me that AC Land Rover Specialists also in Horndean know their stuff and is run by an LR main dealer guy who is also a good friend of one of his guys (which may or may not be a good thing) https://www.aclandroverspecialist.com/
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
These guys are only down the road for Guy Salmon in Portsmouth so could be convenient! If a jobs worth doing, get a someone who knows what they are doing to do it! RRS Autobiography Indus RR P38 HSE V8 RRS Supercharged Santorini AMG CLK Rear Tyre Shredder |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
So sorry to hear this has happened to you PJBracer.
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 55 ![]() |
2014 AB 3.0 crankshaft failure and engine seizure today … 85,000 miles, owned since new, full service history, serviced 3 weeks ago and mot’d (no issues) £10k quoted by local independent LR to replace engine …. No extended warranty in place … any suggestions? 2014 RRS AB Santorini Black |
Bummer Im still looking at options too I wrote and email to the head of JLR and he has passed it down the food chain again but not sure if anything will come of it!
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 158 ![]() ![]() ![]() |
As far as I was aware there are no genuine service cranks available from JLR. When I looked it would seem that the crank is line bored to the block and hence are a matched pair. I know someone who fitted an aftermarket (Chinese) crank and ended up in a right mess with it, end float issues and all sorts and after a lot of building and stripping, binned it and went down the JLR short block route.
Good to know Yeah Im trying to get as much info my guess is the refurb units use an LR gen kit from what they have all said but the block is a recon unit from another vehicle so one would guess that in my case the bearings have failed but the crank still turns over but will be scored with the swarf from the bearings so a refurb my be sufficent, the couple Ive spoken to have said they use the refurb block and the use all the other components from mine, and any of the components from mine that require cleaning and refinishing are kept.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 ![]() ![]() ![]() |
I was under the impression that LR don't release "service parts" to allow a rebuild of a failed engine. Have they changed that policy recently? 2012 SDV6 - it's missing a couple of cylinders
Is that a LR FSH or have you been using indies for servicing? If you have a LR FSH and you've owned it from new, I'd be asking LR for their thoughts on a contribution. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Yeah me to Im still in talks with LR at the moment mine is FLRSH btu Im not the first owner of it and as thee is no warranty the inital response is FO! But speaking with the guys at the LR dealer where she is still sat they said they agreed that there should be some assistance from LR due to it history and mileage!
LR for first 5 years and Indy for last 2 years It looks like it may be cheaper to go down the Indy route if JLR only give 20-30% off their prices 2014 RRS AB Santorini Black |
Mike check your Pms if you wanna gimme a call i just spoke with a company up your way
Just for the records #Outspiration
