Home > Faults & Fixes > Front passenger door wont lock |
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 |
Thanks for the video.. it will be useful once I get beyond the window problem.. I need to remove the glass from the nylon clamps.. this is my problem.. cheers |
Sat Nov 02 2019 2:18pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Thats exactly what they do around 3:35 - remove the glass from the clip. Kev
Sat Nov 02 2019 3:09pm |
Sorry.. i overlooked it.. thanks.. thay does gove me an insight cheers. May need another helping hand to pull the glass. |
Sat Nov 02 2019 3:37pm |
Yes, an extra set of hands to pull the glass upwards will be an advantage. I found it difficult the first time I did it.
Sat Nov 02 2019 3:41pm |
Thank you for your help, i am a lot wiser after your assistance.. Ill give it a go on Monday.. weather permitting. cheers and Thanks. |
Sat Nov 02 2019 6:21pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
When you actually see how it works you can’t believe it’s so simple...
Sat Nov 02 2019 8:53pm |
Thank you for the advice, that sounds an easier method, if indeed the range rover sport window is the same, I'll have a look in the morning. Again I must thank you Farmer for your help and time. Cheers 😊 |
Sat Nov 02 2019 9:23pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
I actualy managed to do a Sport o/s rear one without removing the glass from the motor, just undid the motor assy. dropped it all down and pushed to one side. Not sure if you can do same with front though.
Sun Nov 03 2019 12:29am |
Thanks Col.. good to know cheers. |
Sun Nov 03 2019 11:04am |
