![]() | Home > Technical > Recirculating damper failure |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Under climate or ??? |
IainM58 Member Since: 03 Mar 2019 Location: Prestwick Posts: 15 ![]() ![]() |
In the HVAC section... |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
What is the DTC code that goes with the fault?
Hi all got it cleared today..I ran through the service menu on the IID for the FBH and once it had completed I was able to clear the fault...no idea why the two would be connected but there you go...... |
HVAC - Heating, Ventilation and Air Conditioning. Got lots to do with the Fuel Burning Heater as the HVAC communicates with, sets and controls the FBH. 2019 5.0 SC SVA (Current)
