Home > Maintenance & Modifications > Fitting a winch: Part 2
HughN
Wales
Part 1.
FirstFour made three leads of 0.9m, which allowed the control box to be sited on the bracket.
Before the bumper went on, I used some jump-leads to power the system and check the motor ran (and in the correct sense). The bumper has to be cut to fit around the tray (this ultimately meant cutting-out the areas shown in the yellow boxes as well).
Next thing was to get rid of the plastic webs behind the bumper. I was a bit too conservative and after the picture was taken cut out the adjacent pair of webs.
Using a step-drill, I made a couple of holes so that I could see the fixings for the fairlead (these are internally-threaded round bar). A couple of lengths of threaded rod meant I could slide the fairlead up to the bumper and mark it out.
And then it went pear-shaped...
...rained-off for twenty minutes, I came back and cut to the "wrong" line. Embarassed Big Cry Skoollboy error, ruining what is an otherwise concours vehicle.
With the fittings as supplied, the fairlead would be behind the bumper. I didn't want a big 'letterbox' in the bumper and so added to each side a 25mm spacer (and a couple of washers) so that it sits flush. Only time will tell whether it will remain strong enough under any side-loads.
The gap around the fairlead looks rubbish. I hate myself.
The number-plate holder covers everything.
The clutch lever remains easily accessible.
Even though there is a wireless remote, I cut the wire to the wired remote and wired in an IP68 socket, the solder-buckets on the other side potted with epoxy.
Even part of the car seems to be sharp and/or hot and/or moving so, after staring at it for a long time, the +ve wire was routed in lengths of conduit into the 'battery box' where the ABS is, to an isolator switch and along to the battery via a mega fuse. This was an extended wiring kit in 35 mm² cable.
Off to give the synthetic rope a stretch...
Suggestions for a 'quick release' number-plate mount appreciated!
Post #585201 Sun Aug 11 2019 1:16pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
I think that a hinge could do the work Wink ...and clips to keep it in place TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #585205 Sun Aug 11 2019 2:55pm
Lindab
Try this
speedflip.com
Post #585219 Sun Aug 11 2019 10:50pm
HughN
Wales
∆∆∆ Ha! Excellent! Thumbs Up
Post #585224 Mon Aug 12 2019 6:24am
HughN
Wales
Lindab wrote:
Try this
speedflip.com
Purchased... Cool
Post #585234 Mon Aug 12 2019 9:23am
Pufftmw
Rolling with laughter Rolling with laughter
Why not a small bit of checker plate roughly number plate sized cut to fit and pop-riveted to the bumper?
I would have suggested something like THESE for quick removal of the plate when needed. Might be a bit more practical than the flipper, which in a tow situation might get broken.
Post #585245 Mon Aug 12 2019 11:36am
Lindab
Flipper looks good, remember & post a video when you have it fitted. I'm sure no one would use it when approaching cameras Rolling with laughter
Post #585248 Mon Aug 12 2019 12:21pm
HughN
Wales
There's no 'tongue-in-cheek' emoticon to go with the 'concours' comment.
We have some of those clips on our trailer. Not as cool though!
Good idea. A piece of laser-cut checker-plate might be just the ticket. Thumbs Up
Post #585251 Mon Aug 12 2019 1:08pm
HughN
Wales
[Duplicate post]
Post #585252 Mon Aug 12 2019 1:08pm
Buckster
Good job, always nice to be self sufficient when stuck Wink Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #585265 Mon Aug 12 2019 7:39pm
HughN
Wales
I picked-up some good winch-blankets from eBay - lots of velcro and pockets to add some extra mass. For about four decades we winched boats up the beach on 300 m of steel cable - only twice did it 'let go' and it was quite 'educational'. Shocked
I'm going to replace the isolation switch with a 500 A relay. Doing so will give me scope to run the +ve cable to the battery in some conduit.
Post #585280 Tue Aug 13 2019 7:54am
HughN
Wales
I knew there was another photo. First pass at grounding it. Copper a bit too thick as the nuts don't have threads to the end. Bolt needs brazing...
Someone, somewhere probably sells these.
Post #585745 Fri Aug 23 2019 4:27pm
aaronjb
Check http://www.autoelectricsupplies.co.uk and https://www.12voltplanet.co.uk/ for high current capacity bus bars Thumbs Up
Like this one: https://www.12voltplanet.co.uk/vte-3-point...black.html 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585747 Fri Aug 23 2019 4:55pm
HughN
Wales
First method for gaining access to the winch is Lindab's suggestion, wired into the switch that activates the 500A isolation relay. It is allegedly IP67, but time will tell. Needs a bit of a tweak or two.
Fusion360 -> 3d printer -> car.
And, yes, my car is as clean and tidy on the inside as it is on the outside... Embarassed
Post #586565 Mon Sep 09 2019 6:59am
