Home > Maintenance & Modifications > Fitting a winch: Part 2 |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Part 1.
Sun Aug 11 2019 12:16pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Try this
Sun Aug 11 2019 9:50pm |
∆∆∆ Ha! Excellent! |
Mon Aug 12 2019 5:24am |
Purchased... |
Mon Aug 12 2019 8:23am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Why not a small bit of checker plate roughly number plate sized cut to fit and pop-riveted to the bumper? I would have suggested something like THESE for quick removal of the plate when needed. Might be a bit more practical than the flipper, which in a tow situation might get broken. |
Mon Aug 12 2019 10:36am |
Flipper looks good, remember & post a video when you have it fitted. I'm sure no one would use it when approaching cameras |
Mon Aug 12 2019 11:21am |
There's no 'tongue-in-cheek' emoticon to go with the 'concours' comment.
Mon Aug 12 2019 12:08pm |
[Duplicate post] |
Good job, always nice to be self sufficient when stuck 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Mon Aug 12 2019 6:39pm |
I picked-up some good winch-blankets from eBay - lots of velcro and pockets to add some extra mass. For about four decades we winched boats up the beach on 300 m of steel cable - only twice did it 'let go' and it was quite 'educational'.
Tue Aug 13 2019 6:54am |
I knew there was another photo. First pass at grounding it. Copper a bit too thick as the nuts don't have threads to the end. Bolt needs brazing...
Fri Aug 23 2019 3:27pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Check http://www.autoelectricsupplies.co.uk and https://www.12voltplanet.co.uk/ for high current capacity bus bars
Fri Aug 23 2019 3:55pm |
First method for gaining access to the winch is Lindab's suggestion, wired into the switch that activates the 500A isolation relay. It is allegedly IP67, but time will tell. Needs a bit of a tweak or two.
Mon Sep 09 2019 5:59am |
