udash
![](templates/vbnew/images/spacer.gif)
Update on this, I wanted to try draining the gearbox oil and found this
http://www.disco3.co.uk/forum/topic141425....bies+guide
works for L494, including not needing the special tool that LR shown on the workshop manual as there's lot of space to use a normal hex tool.
Replaced 3.5L of oil, used Westway ZF 8 Speed Lifeguardfluid, 5L for £36.
Oil that I drained was very dark green, that was only after 52,000 miles, I can not imagine same oil being good for another 48,000 miles as per LR instructions.
So after change, upshifting is lot smoother, but still not as good as it was (when new), but biggest improvement is when deaccelerating, downshifting is so much better, with no kickbacks, very close to how it was before. Very happy with the result.
Didn't clear the adaptations.
As many Disco owners, I am going to do another change in few weeks so that will bring the new oil percentage close to half (42%, total gearbox capacity is 8.5Ls) and then probably stick to annual change just like the engine oil.
I think 'Change early and change often' given by Bobbie really is the one to follow for ZF8 ![Bow down Bow down](images/smiles/icon_bow.gif)
Sun Sep 08 2019 6:54pm |
