Home > Technical > 09 parking aid module
Scorpasmithy
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi new here,
Just got my rrs and the parking aid module needs replacing. The part no is YWC500730 see attached photo
. My question is can I replace the module with any of the following modules? YWC500311 > YWC500312 > YWC500313 > YWC500550 > YWC500730 as they all seem to have a different part no on eBay but all look the same.
Post #584910 Sat Aug 03 2019 1:39pm
Not sure about YWC500312 I think it is for very early cars, but YWC500730 is a superseded part number for the other three units.
Post #584916 Sat Aug 03 2019 2:35pm
Early modules enable the fronts and slow speed
Under 10 mph
Post #584919 Sat Aug 03 2019 6:20pm
Surely they all work at low speed wouldn't be much use if some only worked at 50mph. Smile
Post #584920 Sat Aug 03 2019 6:30pm
I think you missed the word enabled Razz Laughing
Post #584922 Sat Aug 03 2019 6:44pm
There was a switch on the dash of my old 09 plate which switched the fronts on and off and the PDC automatically disabled at speeds over 10mph so not unique to early versions.
Post #584923 Sat Aug 03 2019 6:52pm
But how do the front get enabled ? If you just drive forward into a space.
There was a tsb regarding this and explaining part no changes.
Post #584924 Sat Aug 03 2019 7:03pm
Brit Plumber
OP, what’s the symptom before you replace your module? These cars have problems with the wiring to the sensors, it’s very unusual for a module to fail. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584927 Sat Aug 03 2019 10:07pm
You have to switch them on first using the PDC switch, unless you engage Reverse first then into Drive, it's the same on the facelift variant if memory serves me correctly, but could be wrong on that as can't remember last time I used the switch. Not sure what the range is but guess the fronts would keep going off in say slow moving traffic if permanently enabled
Post #584929 Sat Aug 03 2019 10:49pm
That’s what I thought.
Early ones are always enabled under 10 mph.
As I said in my first post.
Post #584942 Sun Aug 04 2019 8:31am
Brit Plumber
That would drive me crazy in a traffic jam. I can see why it was ditched! 2019 5.0 SC SVA (Current)
Post #584943 Sun Aug 04 2019 8:34am
The only issue is when cyclists go past
Or a bus goes the other way.
Though the other day is did beep and I thought what has gone wrong now Laughing
Post #584960 Sun Aug 04 2019 6:10pm
Scorpasmithy
So i replaced the unit and all was fine. parking sensors working perfectly.... until this afternoon. now i have the flashing light and long beep back. any ideas?
Post #585133 Fri Aug 09 2019 4:29pm
Brit Plumber
See my post above ref. Wiring 2019 5.0 SC SVA (Current)
Post #585136 Fri Aug 09 2019 5:19pm
