![]() | Home > General > Which engine oil is best for the sdv6 3.0 diesel |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
DPF models 5/30 C1
As above, and assuming you have a DPF as you have SDV6: 5w30 ACEA C1 spec, meeting Ford WSS-M2C934-B
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
Thanks for the advice.
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Per Knwatkins. Use nothing else. |
Been trying to hunt some oil today 5w30 C1, went to almost every motor shop around me, no one seems to stock the 5w30 c1 grade, Halfords, euro car parts , local motoring shops etc.. Have found some online which delivery takes a day or two, as needed it for tomorrow. Where does everyone else buy there oil? Or is it a trip to the stealers... Thanks |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
Shell garage? 2023 P440e SE Dynamic on order -cancelled
Have used this. As said, personal choice..and there is much discussion on branding and marketing of the so called high end motor oils.
Use Opie oils website. Code “Payday” for 15% off |
Code 5W3015 might work too |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
mobil 5W30 ESP |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Which is best? The one in the book.
