![]() | Home > Technical > Front anti roll bar pipes |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 190 ![]() |
looks like 300 quid for a complete set |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
I imagine they will be LR only parts... |
[url]https://www.ebay.co.uk/itm/Range-Rover-Sport-front-ace-pipes-Range-Rover-Sport-arc-pipe-set-4-2-7-4-2-4-4/253727153951?epid=646585357&hash=item3b13511f1f:g:NykAAOSwhnlb7T6T
Usually, vice grips on the pipes, and twist and lever out
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Is it worthwhile replacing with copper ones? |
just been watching on youtube a guy repairing one with a piece of copper,mine are pretty badly corroded all the way,so would probably just be easier to replace the whole lot.Now pretty much removed all mine ,except out of the valve block,sprayed wd40 all over it,try again tomorrow. |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Really don't think copper pipes is a good idea,
Copper brake pipes have a burst pressure of around 400bar IIRC, but the constant pressure cycles do weaken the pipe over time
Needs more volume than thin brake pipe, thicker copper pipe don't take as much pressure.
[img]
Now spare a thought for those of us who do this on a daily basis |
Have you seen my thread from last year?
I clamped the valve block in the vice,took out the studs and tapped it of ,took a while.
