![]() | Home > Technical > Help restricted performance |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
I don’t know if it’s of any help as I am new to these cars too! I have had FFRR for years and a lot of restricted performance issues were down to split inlet hoses. I had it on my 4.4 TDV8, had to change two of the inlet hoses as they had split. Current: 2010 RRS 3.6 TDV8 HSE
Plugg80 Member Since: 19 Aug 2018 Location: Manchester Posts: 3 ![]() ![]() ![]() |
Thanks Stu I have had issues in the past on others cars with that garage has checked them think I will have to bit the bullet and get a RR specialist to put it on a diagnostic machine. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
Certainly can't go wrong with getting a good indie to take a look, if you have split hoses it's normally accompanied by lots of black smoke, otherwise EGR valves might be a problem. 2010 RRS, TDV8
If the code was P006A, its most likely a split inlet manifold |
Thanks I'll get it looked at just really annoying having had all the work done |
