Home > Technical > Help restricted performance
Plugg80
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi I have a 2010 RRS HSE it's done 112000 just had new battery, timing belt and alternator done and was fine for about 2 weeks then got restricted performance red triangle when I hit around 55mph. Fault code was for MAF/MAP sensor so changed both MAF sensors first then had it checked again this time MAP sensor came up do have changed that tonight with original part. Took for a blast and it came on again and still saying map sensor . Any ideas would be a great help .
Post #583176 Thu Jun 27 2019 10:48pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I don’t know if it’s of any help as I am new to these cars too! I have had FFRR for years and a lot of restricted performance issues were down to split inlet hoses. I had it on my 4.4 TDV8, had to change two of the inlet hoses as they had split. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #583213 Fri Jun 28 2019 6:37pm
Plugg80
Thanks Stu I have had issues in the past on others cars with that garage has checked them think I will have to bit the bullet and get a RR specialist to put it on a diagnostic machine.
Post #583214 Fri Jun 28 2019 6:49pm
gogsy1956
Certainly can't go wrong with getting a good indie to take a look, if you have split hoses it's normally accompanied by lots of black smoke, otherwise EGR valves might be a problem. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #583215 Fri Jun 28 2019 7:01pm
Disco_Mikey
If the code was P006A, its most likely a split inlet manifold
Post #583222 Fri Jun 28 2019 9:07pm
Plugg80
Thanks I'll get it looked at just really annoying having had all the work done
Post #583227 Fri Jun 28 2019 11:46pm
