![]() | Home > General > Tow bar electrics |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Well that definitely wouldn't fit on our MY12/13. 2012 SDV6 HSE (technically its hers)
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Made in 2006.
Paulyh Member Since: 27 Jun 2019 Location: West midlands Posts: 2 ![]() ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If that is for a pre-facelift RRS1 Sport I think you will find that is just part of a kit, there should be a fuse-box that goes in the spare wheel well and a few other brackets, relay's and other bit's and pieces etc. I don't think that will simply fit to the vehicle and you have tow-bar electrics. I can't really remember fully but I think those two small spade end connectors go on the tailgate release switch as you have to remove the original harness and replace it with the new tow-bar one, but could be wrong on that.
even the first part of the early kit should have 2 connectors on the end.
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
Hi guys, hope you don’t mind me butting here!
Yea |
Thanks for that Andy K, wish I’d kept my IID tool when I sold the FFRR now.. |
Land Rover do a 12n/s to euro adapter, it’s about 8” long so doesn’t add much length to your cable. 2019 5.0 SC SVA (Current)
I think that lead is the 'S' plug of Kit YWJ500150 which has One multi pin connector, the 'N' plug has the Two multi pin connectors, so as I said previous I think you will find you only have part of the kit. ![]() Cheers Col |
Brit Plumber, thanks for that, I will look into that as an option. Trailing cable is one of my issues, don’t want it dragging on the floor. Current: 2010 RRS 3.6 TDV8 HSE
Col. This socket is not grey or white, so it is not the 12 S
So which colour is the 'S' socket ? as L/R's kit appears to show two black sockets with one having a grey lid/flap as I was just basing it on the L/R fitting kit illustration which knowing L/R could be wrong.
The one with the "a grey lid/flap" is the S socket |
