Home > General > Tow bar electrics |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
Well that definitely wouldn't fit on our MY12/13. 2012 SDV6 HSE (technically its hers)
Thu Jun 27 2019 10:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Made in 2006.
Thu Jun 27 2019 10:25pm |
Paulyh Member Since: 27 Jun 2019 Location: West midlands Posts: 2 |
Thu Jun 27 2019 10:43pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
If that is for a pre-facelift RRS1 Sport I think you will find that is just part of a kit, there should be a fuse-box that goes in the spare wheel well and a few other brackets, relay's and other bit's and pieces etc. I don't think that will simply fit to the vehicle and you have tow-bar electrics. I can't really remember fully but I think those two small spade end connectors go on the tailgate release switch as you have to remove the original harness and replace it with the new tow-bar one, but could be wrong on that.
Thu Jun 27 2019 11:09pm |
even the first part of the early kit should have 2 connectors on the end.
Fri Jun 28 2019 10:48am |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
Hi guys, hope you don’t mind me butting here!
Fri Jun 28 2019 5:33pm |
Yea |
Fri Jun 28 2019 6:05pm |
Thanks for that Andy K, wish I’d kept my IID tool when I sold the FFRR now.. Current: 2010 RRS 3.6 TDV8 HSE
Fri Jun 28 2019 7:35pm |
Land Rover do a 12n/s to euro adapter, it’s about 8” long so doesn’t add much length to your cable. 2019 5.0 SC SVA (Current)
Fri Jun 28 2019 10:20pm |
I think that lead is the 'S' plug of Kit YWJ500150 which has One multi pin connector, the 'N' plug has the Two multi pin connectors, so as I said previous I think you will find you only have part of the kit. Cheers Col |
Fri Jun 28 2019 10:37pm |
Brit Plumber, thanks for that, I will look into that as an option. Trailing cable is one of my issues, don’t want it dragging on the floor. Current: 2010 RRS 3.6 TDV8 HSE
Sat Jun 29 2019 6:56am |
Col. This socket is not grey or white, so it is not the 12 S
Sat Jun 29 2019 9:04am |
So which colour is the 'S' socket ? as L/R's kit appears to show two black sockets with one having a grey lid/flap as I was just basing it on the L/R fitting kit illustration which knowing L/R could be wrong.
Sat Jun 29 2019 9:51am |
The one with the "a grey lid/flap" is the S socket |
Sat Jun 29 2019 12:07pm |
