Home > Maintenance & Modifications > Engine carbon clean
Cherrymobile1
England 2008 Range Rover Sport TDV6 HSE Java Black
Engine carbon clean
Hi thinking of having my 2008 2.7 diesel carbon cleaned has anybody else had this done and are there any benefits to the running and performance, thanks in advance 👍
Post #582777 Fri Jun 21 2019 1:36am
HughN
Wales
Do you mean stripping the engine down and cleaning it, putting some de-coking stuff into the top end through the air intake, or one of these places where they use some "magic gas" to make everything brand-new again?
I think the jury is still out on the latter but some diagnostic tests (to make sure everything is working) and a whole sump's worth of flushing-oil followed by a whole sump's worth of quality oil may be a better investment.
Post #582817 Fri Jun 21 2019 5:13pm
Cherrymobile1
It’s the latter hughN I’ve read a few reports that it cleans 75% of the carbon deposits from the engine and exhaust increasing mpg and performance , just seeing if anyone else on here has had it done 👍
Post #582820 Fri Jun 21 2019 6:20pm
Eaters
I’m hoping that the Redex I use in each tank full of diesel will do the same job over time. Costs about £1 per tank if you buy it from Tesco when they sell it at half price. Only time will tell if it makes any difference and I may never know. But for a quid I think it’s worth the small effort/expense. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #582927 Mon Jun 24 2019 6:16am
Lindab
I have always been a fan of Redex, but after reading the post "Wynns Formula Gold diesel treatment", I am now using 2 stroke mixed with a tank of fuel. Early days but now think the engine is quieter or I have convinced myself it is Whistle
No one time "Magic Gas" will clean 75% carbon deposits. Do you realise how hard these deposits are. Anything that does work will be a long term change as it will slowly erode the deposits, unless that is if you are removing the head & de-coking it, then you will get an instant fix, but its a bit drastic & expensive.
Post #582939 Mon Jun 24 2019 10:37am
