Home > Technical > Differential rebuild - torqueing spec
Flexzor
Hi,
I'm rebuilding my rear differential of my 2.7 2009 RRS.
The job itself is relatively easy if you have access to a hoist, like I do...
Currently, the differential lies open, 1 bearing was shot (pitting).
Now, i'm ready to assembly again, but is there anyone who can help me on the thightening spec of the pinion shaft-nut?
Thu Jun 20 2019 8:28pm
Barryp
Flexzor,
I had a look in the L320 workshop manual which quotes the following:
"The pinion shaft is mounted on two opposed taper roller bearings, with a collapsible spacer located between them.
The spacer is used to hold the bearings in alignment and also collapses under the pressure applied to the pinion
flanged nut. This allows the flanged nut to be tightened to a predetermined torque, which collapses the spacer,
setting the correct bearing preload."
No mention of the torque anywhere but it does say (and explain with pictures), to scribe a mark on the flange and nut prior to disassembly so that it can be reassembled to the exact same position after reassembly. Its because the spacer has been crushed to some unspecified torque on original assembly at the factory I presume.
Regards
Barry2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Sat Jun 22 2019 2:39am
Flexzor
Unfortunately, i did not write down how much turns the locking nut was turned on the pinion shaft...
I read that the preload can be checked by rotating the shaft, without differential mounted into the housing: it then should be like 2-3-4Nm torque needed to turn. Someone can give me the exact number?
Thanks
Tue Jun 25 2019 6:48pm
Kzwpoas1
Hi Flexzor,
I am having the same issue with my diff. Did you ever get any feedback regarding the torque setting and pre-load.
Also, any idea where I can get a collapsible spacer for a Disco 3 / RRS l320 front diff ( LR006011 or TAG500063)?
Thanks.
