Home > Technical > 2008 TDV6 Oil cooler leaking question?
M9G UK
So I have a little oil leak and have had it in my local garage a couple of weeks ago and they changed the oil filter housing as thought it might be that, it wasn't so they had it back. They have just rung me to tell me they have spoken to a land rover mechanic who says it sounds like it is the oil cooler gasket and told my mechanic it takes them 4 hours to replace so hes quoting me 5 hours as never done one. Hes fine if I don't want to get them to do it, I use to mess with cars and think I am quite capable of replacing it but at my age cant be bothered any more to smack my knuckles. They are quoting me approx. 300 for the job but they cant guarantee it is the fault but are quite confident that it is.
My question is - is it really that much of a pig of a job? and would I be best letting them continue or is it a relatively easy job that I can do at the weekend
Cheers for any input
Thanks 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #580833 Tue May 14 2019 6:56pm
Maybe you should trace the leak yourself
And if you agree it’s the same part get them to change it
Post #580838 Tue May 14 2019 7:29pm
M9G UK
Problem with that is the whole intake has to be taken off to get to it apparently which is what takes the time so if I have to take it all off to see it then I just as well replace it as its all of anyway
Regards 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #580839 Tue May 14 2019 8:05pm
No
The oil cooler filter is in the middle of the engine.
Just pull the plastic cover off. 5 second job
Post #580846 Tue May 14 2019 9:01pm
M9G UK
Its not the filter, they have replaced that, they think its the gasket on the cooler which they say the whole intake needs to come off to replace it or even to see if the leak is coming from there, I must admit I have taken the cover off and had a look and you cant see much in there as there is loads in the way
I think im going to do it myself, I cant throw 300 at it and its not it and then find out it is the cooler itself and need to throw another 300 at it 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #580849 Tue May 14 2019 9:29pm
I thought the cooler was under the filter
Post #580851 Tue May 14 2019 9:36pm
Look for a part on eBay and u will get an idea
Post #580852 Tue May 14 2019 9:37pm
Eaters
If you’re reluctant to do it yourself, can’t you talk to that mechanic they spoke to with a view to him doing the work? At least you’d know someone competent might be doing it. Or find a local independent LR garage who can look it over? You need quality advice and expertise, which is often only available from your local indie; and normally much better and cheaper than the LR dealer. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #580853 Tue May 14 2019 9:37pm
Bardley
Try posting on the Discovery 4 forum. There maybe someone that can help and advise. Same engine... 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #580855 Tue May 14 2019 9:55pm
Top item Fuel cooler lower part Oil cooler. Probably need to go into my gallery to enlarge for better view, and download if you wished.
l
Post #580857 Tue May 14 2019 9:57pm
M9G UK
Yes it is but i'm trying to find out if its a 5 hour job or they are winding me up coz they dont want to do it and I am quite confident in doing jobs myself so was wondering how difficult it is or any special tooling or any complications in doing the job, Ive worked on many engines but never a TDV6
Cheers 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #580862 Wed May 15 2019 6:54am
M9G UK
l
Cheers Col Thumbs Up Thumbs Up
I havent got my car with me so cant have a look but does all the intake need to come off?
Do you know if there is any special tooling or any difficulties i will come across doing it outside my house? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #580863 Wed May 15 2019 6:56am
Don't appear to be any special tools required, but looks like the Crankcase Vent Oil Separator has to be removed first which looks like a fair bit of work. Might be worth downloading the W/shop manual and having a good read first and then decide if you want to tackle it.
http://www.mediafire.com/file/yunzrqm47py4...6.pdf/file
Post #580864 Wed May 15 2019 7:19am
M9G UK
Ok cool many thanks Col appreciate yours and Andy K help Thumbs Up Thumbs Up Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #580865 Wed May 15 2019 7:23am
It's not difficult.
The inlets and camcover are combined. I don't believe they need to be removed for this job. (they are a pain to remove)
The Y inlet requires removal. It lifts up.
Tools are typically 8mm socket and torx bits.
I recommend you purchase a gasket.
purchase a second hand oil cooler
and have a go at doing the job yourself.
You will probably be finsihed before you know it
Post #580872 Wed May 15 2019 11:07am
