Home > In Car Electronics > Low power mode on radio |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702 |
If the battery is the original one it may need changing these cars need a good battery |
Thu May 02 2019 5:43pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Your car radio will be back when the car's systems see good battery capacity - the car reduces power to a range of systems, including the radio when available electrical power is reduced - charge the battery by driving or battery charger and if the battery has actually failed then obviously a new one will be required.
Fri May 03 2019 12:13am |
