Home > General > Range Rover sport poor acceleration
Chromer2828
United Kingdom 2008 Range Rover Sport TDV6 HSE Alaska White
Hi all new to the forum. I recently bought a Range Rover sport tdv6 2008. Noticed on the test drive it was a little slow to respond. Coming home down the motorway it was smoking quite a bit out the back. Seemed ok for a week but now I have a problem with pulling off. It literally pulls off at a snails pace and then eventually takes off. I found a split in the turbo hose and replaced that one and thought I’d cured it but unfortunately no.
My research shows maybe egr valves. Being a 2008 I don’t think I can blank them off, help or advise here would be great. If I can’t then maybe I’ll replace them. Any advice or pointers please, only had the car a couple weeks, absolutely love it but I’m gutted
Post #579925 Mon Apr 29 2019 6:25pm
shepp
May be worth adding.
https://www.eurocarparts.com/ecp/p/car-acc...gJa4vD_BwE
My 2012 was smoking a little when I bought it and found it very frustrating setting off,. I put a bottle of Wynn's extreme clean 3 in half a tank, then took it for a good run. It dropped. Huge amount of black on an Audi. But it made a massive difference. I don't have any more smoke at all and the power increased massively. it's worth a punt for £13.
It appears the injectors, and other bits were gunked. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #579928 Mon Apr 29 2019 7:07pm
you can certainly blank them as a test to see if it is EGR related.
Other thing is turbo actuator rod
Post #579929 Mon Apr 29 2019 7:34pm
Chromer2828
Thanks for the replies, I will get some of that Wynn’s and chuck it in nothing to lose. The actuator on my turbo is moving ok as far as I can see.
Post #579931 Mon Apr 29 2019 7:54pm
Brit Plumber
Turbo? Or Turbos? The TDV8 has 2 so if the turbo rod is moving fine on yours you may want to check the other one if you haven't. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579940 Mon Apr 29 2019 8:51pm
He's got an early TDV6 so single turbo. 2012 SDV6 - it's missing a couple of cylinders
Post #579949 Mon Apr 29 2019 10:08pm
Brit Plumber
Lol, sorry misread it as TDV8, 2019 5.0 SC SVA (Current)
Post #579950 Mon Apr 29 2019 10:10pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
Sticky turbo actuator rod will cause that. You can get at it from top or bottom. From top its battery and battery tray out; from underneath you can take the heatshield off to see it. You should be able to move it back and forth with ease (about an inch travel). If not, it is seized and wants lubricating and working back and forth until free.
Post #580021 Tue Apr 30 2019 8:23pm
Chromer2828
Thanks for the reply, the actuator rod is what controls the wastegate. Is it easier to get at with the battery out than through the wheel arch thanks in advance
Post #580193 Fri May 03 2019 5:45pm
No
Wheel arch
Post #580194 Fri May 03 2019 6:08pm
Chromer2828
Even though I can hear it, is it still possible it’s not moving
Post #580196 Fri May 03 2019 6:51pm
The egrs also make a noise at similar times.
Post #580199 Fri May 03 2019 7:40pm
gary3306
Actually if the rod is stuck, it is normally accompanied by the message ‘Engine System Fault’ on the dash, that keeps flashing up every 20 seconds or so. If you can hear it and you don’t have that fault on the dash, chances are it isn’t that. Induction leak somewhere. And it is easier to get at through the wheel arch
Post #580203 Fri May 03 2019 7:58pm
Chromer2828
All doom and gloom for my range, I took it out this morning and she started smoking. Then the cab started to fill with smoke. I pulled over and the manifold on the right hand side had holes blown in it and it was smoking out of them. Called recovery and the guy said he’d seen it quite often. He told me the egr on that side was faulty and it causes intense heat. The car starts and ticks over fine so hopefully not too much damage. Started taking of the intake manifold which is a nightmare job so far. Intend to replace it along with both egr valves and pray the car will be ok. 2 weeks of ownership, not the best start
Post #580251 Sat May 04 2019 1:19pm
knwatkins
Do you have any kind of warranty where you bought it from? Kev
Post #580256 Sat May 04 2019 1:52pm
