![]() | Home > Off Topic - Other Cars > Who has an Evoque on here and does it’s turbo whistle?! |
I’ve also got a my15 64 plate evoque 2.2 as well as the RRS & I haven’t noticed the turbo whistle when I’m driving if,in fact you can hardly hear the engine at all.Sounds like you could have a problem with the turbo,might be worth messaging Disco mickey on here & ask him as he is the LR tech guy. Andy.
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Thanks tyrefitter that’s good to know |
No Evoque does not normally make any turbo noise - your garage doesn’t know what they are talking about. Tell them to take it at their expense to be fixed at a main dealers or a make specialist Independent
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Sounds like you have a turbo bearing problem that is allowing the shaft to wobble. Most likely due to oil dilution on this engine. A common problem we've seen many times and replaced many turbos.
Thank you everyone! Good to hear I’m not the only one that thinks this is not normal!
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
All turbos have a little bit of whistle if you listen out for it. If I were you I’d got to another dealer and test drive a couple of similar cars (engine and age) to yours. See for yourself if “they all do that”. RRS MY17 SDV6 AB
When you say they all whistle do you mean they sound like there’s ambulance sirens? I have what sounds like ambulance sirens in the distance kind of noise that as the auto changes gear on accelerating changes the noise like a siren. This is normal in all evoques?! |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
On my old 2.2 Evoque, I could occasionally hear the turbo, but it was never loud or intrusive. Most of the time I would say I didn't notice it. |
