Home > Wheels & Tyres > All Terrain Tyres |
I fitted 275 45 20 on mine better ride and better for the rims as they got more side wall |
Mon Apr 22 2019 3:22pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Ideally you'd go to 19s and fit 255/55. That would give slightly more sidewall than the 275/45/20 already mentioned and gives a reasonable number of tyres to choose from. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 22 2019 4:50pm |
^^^^^ what he said 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Mon Apr 22 2019 6:11pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Any issue with 19s fitting over calipers or anything like that or is it a straight swap, no speedo discrepancies or anything? |
Mon Apr 22 2019 8:34pm |
I run 19s on my SDV6 and ran the same rims on my previous TDV8 which had the four-pot calipers. No issues with either.
Tue Apr 23 2019 8:36am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Also, only certain variations of 19" wheels fit over Brembo callipers, if you have them. Do a search on here for which ones. |
Tue Apr 23 2019 1:52pm |
kevin-h Member Since: 05 Nov 2010 Location: France Posts: 7 |
I have a 2009 TDV6 HSE facelift and have just done the same about a week ago.
Tue Apr 23 2019 3:19pm |
Sorry,
Tue Apr 23 2019 3:26pm |
All of the above really does help a great deal...
Wed Apr 24 2019 9:41am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
if you want to stay on the 20s, you can also go 255/55R20 --
Wed Apr 24 2019 12:07pm |
Thanks for all the advice everyone, as a forum newbie it's lovely to have sensible responses to my queries..
Wed Apr 24 2019 3:48pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
i run General Grabber on my MY10 3 litre oil burner, basically had 3 tyres go in 2 trips, and i take
Fri May 24 2019 7:26am |
The problem with sidewalls is that if you find the wrong bit of rock, it'll take out the sidewall no matter what. We can't easily get the tougher tyre options on the RRS (at least in the UK) so it's always going to be a risk. On three trips around Les Comes (which is all stony/rocky) I only ever suffered a couple of minor surface marks. A trip to mid Wales in a mix of stony and muddy environments saw me suffer a cut down to the cords (not enough to hole the tyre or cause a bulge). Those trips were a mix of Grabber AT (Les Comes) and Grabber AT3 (Les Comes and Wales). One of the vehicles on the Wales trip suffered a puncture on the road section having safely completed the Strata Florida on pure road tyres.
Fri May 24 2019 7:57am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Just get 255 55 20's and keep your existing wheels. The newer sport came with 255, 55 20 as standard. I have them on mine with no issues. If you are concerned about the tyre circumference, you can use the iid tool and change the config to 55's MY12 RRS HSE
Fri May 24 2019 7:59pm |
