![]() | Home > Technical > Transmission Fault Light |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
So there is a connector under the M *-
jaybyname Member Since: 20 Apr 2019 Location: Teesside Posts: 4 ![]() ![]() ![]() |
Everything plugged in. Everything lights up perfectly. Info display in dash just says transmission Fault with a picture of a book next to it. Tried disconnecting the battery to reset ECU but nothing happened |
Probably want to go over your steps again, testing it half way Thru.
Not sure if that will work, unplugging and plugging back in. Surely the car just recognised a fault then threw a light up. |
