Home > Technical > Transmission Fault Light
jaybyname
United Kingdom 2007 Range Rover Sport TDV8 HST Zermatt Silver
Hi all, pulled my centre console out to repaint the silver trims and unplugged the necessary wires for better access. Put everything back together, plugged it all back in and now the transmission Fault indicator lamp has popped up. Can this be reset?
Bloody hope so.......🥴
Post #579336 Sat Apr 20 2019 6:21pm
So there is a connector under the M *-
And another under the prnd
Did you plug both back in and do they light up
Post #579337 Sat Apr 20 2019 6:26pm
jaybyname
Everything plugged in. Everything lights up perfectly. Info display in dash just says transmission Fault with a picture of a book next to it. Tried disconnecting the battery to reset ECU but nothing happened
Post #579339 Sat Apr 20 2019 7:14pm
Probably want to go over your steps again, testing it half way Thru.
Or read fault codes
Post #579341 Sat Apr 20 2019 7:36pm
jaybyname
Not sure if that will work, unplugging and plugging back in. Surely the car just recognised a fault then threw a light up.
Post #579344 Sat Apr 20 2019 7:59pm
