![]() | Home > In Car Electronics > Problem playing MP3s on memory stick (L494) |
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 63 ![]() ![]() |
Help needed with an irritating issue playing MP3s via a memory stick
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
Could it be different bit rate? |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Remember the mp3 is just the container, Many codecs are used with converting to mp3 . I found that many "Downloaded" mp3s using some weird Chinese codec that didn't work in my Sport. I had to re-encode them with Lame encoder on Audacity and they all worked fine ![]() Give that ago. Mines a 2012 so possibly the same Infotainment system as yours . My money will be on the encoder used ! |
Thanks all for the suggestions. It's possibly the converter I used. All the originals were converted from MP4 to MP3 using 'Ummy'. The latest were converted using 'Convertilla' as I'd run out of free conversions for 'Ummy' and I'm too mean to pay for software. Might try to find an alternative and see if that makes any difference. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
See http://www.rrsport.co.uk/forum/topic50824-15.html
Problem solved-thanks all.
