Home > Wheels & Tyres > Will a 22in spare fit in the carrier. 2008 Sport HST
Jampot1979
Hi, I have 22's on my Sport now. Noticed that the spare is a 19in. If I was to get hold of a spare 22, do you know if if would fit underneath in the carrier? Thanks
Post #579253 Fri Apr 19 2019 10:41am
Brit Plumber
Should do, as long as the overall width and diameter of the wheel don’t change to much. The centre will be the same as that’s how it fits to the flange on the hub. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579259 Fri Apr 19 2019 12:14pm
Would be dependent on tyre size fitted, I managed to squeeze a 275/45 x 21" in but it is very tight and needed a bit of work with a Dremel, anything bigger than a 285/35 x 22" I think would be a bit of a struggle.
Post #579260 Fri Apr 19 2019 12:39pm
