Home > Wheels & Tyres > Will a 22in spare fit in the carrier. 2008 Sport HST |
Should do, as long as the overall width and diameter of the wheel don’t change to much. The centre will be the same as that’s how it fits to the flange on the hub. 2019 5.0 SC SVA (Current)
Fri Apr 19 2019 12:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5018 |
Would be dependent on tyre size fitted, I managed to squeeze a 275/45 x 21" in but it is very tight and needed a bit of work with a Dremel, anything bigger than a 285/35 x 22" I think would be a bit of a struggle.
Fri Apr 19 2019 12:39pm |
