Home > General > Wedge Method...!? |
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 |
Firstly, apologies again for YET ANOTHER mindless "help me" thread where I publicly demonstrate my ignorance.
Thu Apr 18 2019 5:23pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
Shoes Part number ending 46 |
Thu Apr 18 2019 6:24pm |
Thank you, I'm sure I've seen that - I will try and find it, hopefully ther wedge bit is in there and I can print it out for the mechanic. |
Thu Apr 18 2019 6:27pm |
That's where I'd gotten to... and "liners" appear not to be mentioned...? |
Thu Apr 18 2019 6:28pm |
You don’t need liners
Thu Apr 18 2019 6:50pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
http://www.disco3.co.uk/forum/topic25409.h...nge+bushes
Thu Apr 18 2019 7:03pm |
I am have missed something as I have only on emmerdale 2010 RRS, TDV8
Thu Apr 18 2019 7:04pm |
That translates into watching emmerdale! 2010 RRS, TDV8
Thu Apr 18 2019 7:05pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
Could they actualy mean shoes and linings, as L/R just refer to the complete item as Kit - Brake Lining, I think the shoe kit ends 47 not 46 that is the pawl actuator rod, also unless they have changed it if you buy a genuine L/R kit it only does one wheel, so you need two kits. I also think they may mean wedge adjuster not wedge adjustment. 7. CAUTION: The wedge adjuster must be correctly seated to make sure the park brake cable is correctly adjusted. Failure to follow this instruction may result in damage to the park brake system. Loosen the wedge adjuster Allen screw half a turn. Tap the brake disc lightly with a soft faced mallet, around the park brake shoe location within the brake disc. Tighten the wedge adjuster Allen screw to 6 Nm (5 lb.ft). Cheers Col |
Fri Apr 19 2019 12:59am |
I have a plan forming.
Fri Apr 19 2019 5:22pm |
This makes sense - although I now can't get the site to load to identify the "kit" - do you have a direct link as opposed to the part number? Might have to wait and ring Tuesday otherwise.
This makes sense too... thank you! |
Fri Apr 19 2019 5:24pm |
Same link as above in a previous reply and works for me, the part number of the kit is LR031947 because I have a pair of these kits in my garage and that is the number on the box. If you google the number I'm sure there are some cheap pattern parts out there.
Fri Apr 19 2019 9:28pm |
