![]() | Home > Faults & Fixes > Fault code P0234 |
Wilco Member Since: 20 Mar 2021 Location: Somewhere in Time Posts: 31 ![]() ![]() |
Just had same code come up and like you engine seems to be running fine.
Sold car last year,,later on after that happened I had problem with throttle body sticking,you could try some throttle body cleaner on the flap inside to help it,mine in the end went into Lr & had new throttle body fitted under warranty. Andy.
Thanks, I found the thread about it and your photo of throttle body clip. So just removed mine and flap was a bit sticky so freed it and just off to Halfords to get some cleaner to spray on.
Make sure it’s throttle body cleaner,,you don’t want anything going in the inlet to f@@k it up. Andy.
Scootrover Member Since: 27 Sep 2021 Location: Staffordshire Posts: 4 ![]() ![]() |
Hi all, I am hoping you can help or share your wisdom!
Throttle body sticking,I had same problem & LR fitted new throttle body under warranty.You could pull the pipe off the throttle body & spray with throttle body cleaner as it will free it off but don’t know for how long.Put a screwdriver under the metal clip pictured & pull it up then pull pipe off.
Thanks for the update, the light came back on today during a very steady drive home 😩
Andrei Member Since: 04 Feb 2024 Location: Constanta Posts: 3 ![]() ![]() ![]() |
How did you solved the issue . I have the same thing with the overboost and dpf not regenrating . I ve change the throttle body and the map sensor and the overboost came back ! Please help i just bought the car and i dont know what else to do ! |
