![]() | Home > In Car Electronics > Alarm/Smart Key Not Found Issue |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I had the key not found message and changed the batteries in both fobs. This seemed to solve the problem for a couple of quid.
Octane85 Member Since: 17 Mar 2019 Location: Wrexham Posts: 40 ![]() ![]() |
Thanks for the reply..
so, this afternoon, on top of the alarm/smart key issues I've now got a Park Brake Fault.
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
If it's been sat at the dealers for a while it may be worth giving the battery a good charge with a decent charger/reconditioner lke a CTEK. 2016 Black SDV8 Autobiography
What should the battery voltages be on one of these?
Mine tends to be at 14V when running and around 12.2V at startup. 2016 Black SDV8 Autobiography
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Ditto mine. |
Ok, so I replaced the battery last night and it's not made any difference.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Are you sure you are not pressing the approach lighting button at the same time as the lock button on the fob.
I'm definitely only pressing the lock button... but... I have changed the fob to the newer style one, so I wonder if the buttons aren't quite aligned properly. That would answer that one I suppose.
You say you replaced the fob, what exactly did you do? Could be a comparability issue. 2019 5.0 SC SVA (Current)
Just changed the case mate, not the actual PCB.
Does it look the same as this? There are different cases where symbols are in a different place.
mine looks like that except it has 'Range Rover' on the chrome side part.
