Home > In Car Electronics > Alarm/Smart Key Not Found Issue |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I had the key not found message and changed the batteries in both fobs. This seemed to solve the problem for a couple of quid.
Sun Mar 24 2019 10:42am |
Octane85 Member Since: 17 Mar 2019 Location: Wrexham Posts: 40 |
Thanks for the reply..
Sun Mar 24 2019 3:46pm |
so, this afternoon, on top of the alarm/smart key issues I've now got a Park Brake Fault.
Sun Mar 24 2019 5:45pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
If it's been sat at the dealers for a while it may be worth giving the battery a good charge with a decent charger/reconditioner lke a CTEK. 2016 Black SDV8 Autobiography
Mon Mar 25 2019 8:31am |
What should the battery voltages be on one of these?
Mon Mar 25 2019 8:37am |
Mine tends to be at 14V when running and around 12.2V at startup. 2016 Black SDV8 Autobiography
Mon Mar 25 2019 8:46am |
Ditto mine. |
Mon Mar 25 2019 10:07pm |
Ok, so I replaced the battery last night and it's not made any difference.
Thu Mar 28 2019 8:56am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Are you sure you are not pressing the approach lighting button at the same time as the lock button on the fob.
Thu Mar 28 2019 9:40am |
I'm definitely only pressing the lock button... but... I have changed the fob to the newer style one, so I wonder if the buttons aren't quite aligned properly. That would answer that one I suppose.
Thu Mar 28 2019 9:45am |
You say you replaced the fob, what exactly did you do? Could be a comparability issue. 2019 5.0 SC SVA (Current)
Thu Mar 28 2019 9:58am |
Just changed the case mate, not the actual PCB.
Thu Mar 28 2019 10:47am |
Does it look the same as this? There are different cases where symbols are in a different place.
Thu Mar 28 2019 1:09pm |
mine looks like that except it has 'Range Rover' on the chrome side part.
Thu Mar 28 2019 1:33pm |
