Home > General > Parking Sensors
TubaPlayer
Parking Sensors
I have started getting the Cameras Not Available warning starting the car.
Checked the falts using the IID tool and it shows that there is no signal from any of the rear sensors.
I have tried changing the module but that comes up with the same errors adn also when checking the ECU info it shows a different VIN no. (probably the original vehicle), does this need updating to the new VIN and if so how?
Is this likely to be a sensor issue?
I have tried checking the distance on the live values but this just shows a constant 2.5m.
Any help woould be greatly appreciated.
Stephen 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #577439 Wed Mar 20 2019 9:31am
Brit Plumber
Can you post the DTC?
Is it an issue with the cameras or the sensors?
The rear sensors communicate the signals to the Camera module over the Medium speed CAN so if you have sensors not working and cameras not working it sounds like separate faults. If the sensors aren’t working you would lose the overlay on the reversing image with an icon at the top with a line through it.
The Vin on the module should have no effect as I have a 2014 FFRR module in mine. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577440 Wed Mar 20 2019 9:39am
TubaPlayer
The sensor fault takes out the camera. If I disable the parking sensors in the ccf the camera works fine. 2016 Black SDV8 Autobiography
Post #577441 Wed Mar 20 2019 9:48am
TubaPlayer
This is the fault data with the new module:
PAM-Parking Aid
• B1B44-01 (2F) Rear right outer sensor - General failure information - general electrical failure
( on 19-08-2013 20:56:13 at 0 km )
• B1B46-01 (2F) Rear right inner sensor - General failure information - general electrical failure
• B1B48-01 (2F) Rear left outer sensor - General failure information - general electrical failure
• B1B50-01 (2F) Rear left inner sensor - General failure information - general electrical failure
• U3002-81 (2E) Vehicle identification number - Bus signal/message failure - invalid serial data received
( on 20-03-2019 09:50:30 at 82971 km )
The old module is the same but without the last code. 2016 Black SDV8 Autobiography
Post #577442 Wed Mar 20 2019 9:54am
Brit Plumber
I’ll take a look at the codes tonight. It appears it’s on the bus as it’s picking it up. 2019 5.0 SC SVA (Current)
Post #577445 Wed Mar 20 2019 11:11am
Brit Plumber
Wiring harness fault
Rear Right Outer Sensor - Component internal failure
Refer to electrical wiring diagrams and check the rear bumper harness for damage/corrosion. Check sensor circuit for short circuit to ground, short circuit to power, open circuit. Repair or replace any wiring harness as required
Check the connector for integrity and damage, then reconnect sensor to confirm connection
Using the manufacturers approved diagnostic system clear the DTC and run the on demand self test If the problem persists remove the suspect sensor from the bumper. Inspect the sensor connector for signs of water ingress/corrosion. Exchange the suspect sensor with another sensor within the bumper that is not reporting a fault. Clear the DTC and run the on demand self test to confirm if the fault code now appears for the new position of the suspect sensor. Renew the faulty sensor
Rear Right Inner Sensor - Component internal failure
Refer to electrical wiring diagrams and check the rear bumper harness for damage/corrosion. Check sensor circuit for short circuit to ground, short circuit to power, open circuit. Repair or replace any wiring harness as required Check the connector for integrity and damage, then reconnect sensor to confirm connection Using the manufacturers approved diagnostic system clear the DTC and run the on demand self test If the problem persists remove the suspect sensor from the bumper. Inspect the sensor connector for signs of water ingress/corrosion. Exchange the suspect sensor with another sensor within the bumper that is not reporting a fault. Clear the DTC and run the on demand self test to confirm if the fault code now appears for the new position of the suspect sensor. Renew the faulty sensor
Same as above
Same as above
No DTC U3002-81 listed but I suspect it to be U3002-81 which is below. I wouldn't worry about it but as the fault doesn't look to be module, I would put the original back on.
VIN Mismatch, stored VIN does not match broadcast VIN
Using the manufacturers approved diagnostic system clear the DTC, cycle the ignition off, then on, and check if the DTC
is still logged If the DTC is still logged replace the parking aid control module.
It looks like it could well be your wiring loom. It could be worth doing a resistance check and carefully checking each wire. Check the connectors that are common to all 4 sensors, just 2 wires are common so a pretty easy check.
Post #577596 Thu Mar 21 2019 9:21pm
TubaPlayer
Thanks, that helped a lot.
There was a corroded Brown in the loom. So chopped out and a new piece put in and all is good now.
Post #577687 Sat Mar 23 2019 2:02pm
ifelton76
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
Good morning all
I seem to have exactly the same faults with the loud bleep on start up, 6 flashes from the parking aid button and cameras not available warning on the main screen, see screen grab from my GAP IID and listed below
Can anyone guide me as to what the route cause is?
Is it just a problem with the rear parking sensor wiring loom or could it be a parking sensor failed and or the parking aid module.
Any help would be appreciated.
Regards
Ian.
Post #630627 Tue Feb 07 2023 6:43am
ifelton76
Sorry forgot to mention this is on a 2012 L320 Range Rover Sport Autobiography.
Post #630628 Tue Feb 07 2023 6:46am
