Home > Technical > AFS Headlight Issue |
lkdgndg1 Member Since: 15 Jan 2021 Posts: 32 |
Hi I’ve just noticed that my RRS has AFS and doesn’t work and never worked in the year that I have owned the car and never had any warning lights on the dash and no messages , fuses checked ok , could this have been disabled in the past . |
Sat Oct 02 2021 9:34am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Whilst I don't know the answer to your direct question, can I just ask a couple of stupid questions? Are you sure you have AFS? Check the label on the headlamps and in the yellow bit it should say "UK-AFS" if you have (would have thought you should have on that year and model). Secondly why do you say that they aren't working? Its a quite subtle movement. Best way to test is to turn your lights on at night before you start the car and watch the headlamp beams. If they go through a "dance" before settling then your AFS is working. For all I know you are an expert and so these questions are just annoying but... Robin
Sat Oct 02 2021 9:57am |
Hi and thanks for the reply , yes both headlamps have the correct sticker and the AFS power module at the base of each headlamp . I parked the car in front of my garage door and switched it on and not even a tiny movement from the headlamps and I don’t get a warning light , so I was just wondering if it could have been disabled by a previous owner but for what reason I don’t know , a bit like my steering column adjustment ,that don’t work either . |
Sat Oct 02 2021 10:08am |
Hmmm. Sorry then I still don't know the direct answer as to whether switching them off is possible. If I had to gamble I'd say no as I am sure over the 3 years or so I had problems with my headlights (and bored people on here silly with them), I would have thought some of the wise owls on here would have suggested that as an option for me - but they didn't. It's not a fuse thing is it??? Other than that perhaps a local indie can plug it in for you and see what they can see Robin
Sat Oct 02 2021 10:38am |
I’ve checked the fuse which is ok but one thing that I’ve noticed is that when I switch on and check the warning lights there is no AFSwarning light |
Sat Oct 02 2021 10:55am |
Aha! Over to the experts then - lets see what others on here can suggest. Sorry I was not more help. Robin
Sat Oct 02 2021 11:36am |
That’s ok thanks , I was just looking into trying to improve my headlamp performance and thought the drivers side was aiming a bit low and won’t adjust up a bit even when trying to adjust , then I noticed that there was the AFS system fitted and also my owners book says it should have D2s bulbs fitted whereas mine has D1s and I don’t think I could fit D2s as they need a separate ballast box , but thanks anyway |
Sat Oct 02 2021 11:44am |
