![]() | Home > Maintenance & Modifications > Door puddle lights not working |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Mine throws that fault up on a regular basis although there working fine, I just put it down to the fact that I have a couple of the projector lamps fitted to the front doors.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5038 ![]() ![]() ![]() |
They are £425
dkelly Member Since: 15 Mar 2019 Location: Cardiff Posts: 9 ![]() ![]() ![]() |
Hi Andy, thank you for the info. I'd like to get the lights working but at £425 I think i might leave it for the moment especially if there's no guarantee that the error reset will resolve the problem. |
WARPYB1 Member Since: 24 Nov 2022 Location: Bedfordshire Posts: 2 ![]() ![]() ![]() |
Hi everyone just did the same thing now front puddle lights don’t work in passenger or drivers but rear ones work fine ? Did anyone find a fix ? |
Load resistors such as the ones Osram offer should work. I’m using them in my front doors with no problems. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Kasket Member Since: 05 May 2023 Location: 95959 Posts: 1 ![]() ![]() |
Same thing happened with mine only the front bottom of the door lights wouldn't work. I just recently spliced into both front and rear fog light harnesses for a couple light bars. Blew fuse #25 (10) and replaced it with a (15) now the lights sometimes come on when i open the door while driving. Anyone solve this issue yet? |
