![]() | Home > Technical > Multi Media Module (HLDF) Country - Japan |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
I may be wrong here, but I though there is something completely different about the Japanese system/electronics etc. as all the Navigation Units, Radios, DVD player etc. are listed specifically for Japan and were not compatible with the ROW system. Which is why you can't get those items to work in Japanese Spec. vehicles imported into the likes of the UK. but I may have that all wrong.
I’m in complete agreement which is why I find it odd that my car has Japan in the “as built data”. I think I’ll change it to “rest of world” and see what happens.
Not sure how cameras are configured but all mine, doors, front bumper and rear will all work at any speed, can't remember if have to switch them on to display before moving or before reach certain road speed though.
Thanks Col, I thought I read that cameras were inhibited above 5mph but you’re the second person to say theirs works at all speeds.
As well as the Gap II diag. tool I also have a Backbox Solutions Faultmate one as well which allowed me to download a copy of the CCF file config. As I said with cameras they do switch off above a specific speed normally, but I put a shortcut on the home screen which allows them to be activated without going into the extra features menu, but as I said I can't remember at which point I use the shortcut to switch them on so they stay on all the time or you can have just rear rear on, mirrors only or fronts only, when I'm out tomorrow will I will check it out.
That’s interesting as I’m using the black box solutions Genesis programme to compare the asbuilt CCFs but it’s not as detailed as your downloaded asbuilt data. If I get chance today I’ll play with the JLR SDD and VCM2 to see what it can tell me.
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
My surround Cameras work at any speed also. |
Success!! I think....
Sorry to say it's the big roof sensor on the roof in the middle. I have it on mine for the front screen and rear entertainment. |
Thanks for that, I had read there were 2 sensors but could only find one. I can get one for £30 but they are all just the IR unit without the alarm sensor housing. Wiring and fitting shouldn’t be a huge issue if I can just get the unit. 2019 5.0 SC SVA (Current)
Sirbastion Member Since: 21 Jun 2022 Location: Wigan Posts: 1 ![]() ![]() |
Sorry to resurrect this thread after so long, but I am fascinated to finally find someone who has gone through similar woes to those I am currently experiencing. I own a 2011 Jaguar XJ (X351 new body shape) and have retrofitted a dual view screen. When my car was built it did not have this installed. I’m aware the vehicles are different but the description of the process sounds very similar - I have updated some values in the CCF and most of the dual view system is now active.
