![]() | Home > In Car Electronics > Dash Cams |
Ive got a Thinkware 770 & its very good in my mind as it also has wifi to download info from cam to fone real easy. Andy.
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
I have the Qvia AR790 in my RRS (front and rear), and am generally very pleased with it. I then had a Thinkware F770 (f&r) installed in my wife's MINI and that also has a(n updatable) speed camera database in it which is useful.
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
Ta for that
Does it alert you to speed cameras ? |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
i was doing a search on that topic myself last week.
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
Thinkware X550 front and rear here, been superb. Great for parking mode and time lapse also |
Anyone have any issues with over night parking or battery drain ?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The Thinkware F770 has a battery monitoring feature built in to the camera, which you can set if battery drop below specific voltage camera turns itself off. Never had any issues with flat batteries with either Blackvue or Thinkware over the years. Had the F770 for at least three years now never been any problem at all
SVR fan Member Since: 03 Mar 2019 Location: Surrey Posts: 28 ![]() ![]() |
I have just this week had the BlackVue installed, 2 channel front and rear. Currently installed with the power magic pro that helps preserve the battery whilst in park mode, ie it switches the cameras off when it recognises the battery has gone below a certain level (~12V). I have it hard wired vs. using the cig’ lighter.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
+1 for the Thinkware F770. As stated, it will turn off from parking mode if the car battery level falls below a certain value which you can set in the menu. It does give warnings of both fixed and mobile speed camera's (can get a bit wearing at times). You can choose if you want the GPS speed recording on or not depending on the weight of your right foot (I have mine on).
If I remember right the F770 also has a basic Lane Departure and Forward Collision warning system fitted which can be switched on or off as required, mine is turned off as I got fed up with all the "bing's and bong's". I also think it gave a warning at mobile speed camera location even if there was not a camera there, which as stated was annoying.
Any views on whether a dash cam install (hardwired) impacts the warranty (question in the Op) |
Thinkware 770 |
Thanks for all the above input/comments, seems there's more to this than meets the eye
