Home > In Car Electronics > Dash Cams |
Ive got a Thinkware 770 & its very good in my mind as it also has wifi to download info from cam to fone real easy. Andy.
Thu Mar 07 2019 4:15pm |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 |
I have the Qvia AR790 in my RRS (front and rear), and am generally very pleased with it. I then had a Thinkware F770 (f&r) installed in my wife's MINI and that also has a(n updatable) speed camera database in it which is useful.
Thu Mar 07 2019 4:27pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
Ta for that
Thu Mar 07 2019 4:28pm |
Does it alert you to speed cameras ? |
Thu Mar 07 2019 4:29pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
i was doing a search on that topic myself last week.
Thu Mar 07 2019 5:44pm |
Thinkware X550 front and rear here, been superb. Great for parking mode and time lapse also 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Mar 07 2019 5:56pm |
Anyone have any issues with over night parking or battery drain ?
Thu Mar 07 2019 7:01pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
The Thinkware F770 has a battery monitoring feature built in to the camera, which you can set if battery drop below specific voltage camera turns itself off. Never had any issues with flat batteries with either Blackvue or Thinkware over the years. Had the F770 for at least three years now never been any problem at all
Thu Mar 07 2019 8:19pm |
SVR fan Member Since: 03 Mar 2019 Location: Surrey Posts: 28 |
I have just this week had the BlackVue installed, 2 channel front and rear. Currently installed with the power magic pro that helps preserve the battery whilst in park mode, ie it switches the cameras off when it recognises the battery has gone below a certain level (~12V). I have it hard wired vs. using the cig’ lighter.
Thu Mar 07 2019 8:21pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
+1 for the Thinkware F770. As stated, it will turn off from parking mode if the car battery level falls below a certain value which you can set in the menu. It does give warnings of both fixed and mobile speed camera's (can get a bit wearing at times). You can choose if you want the GPS speed recording on or not depending on the weight of your right foot (I have mine on).
Thu Mar 07 2019 8:53pm |
If I remember right the F770 also has a basic Lane Departure and Forward Collision warning system fitted which can be switched on or off as required, mine is turned off as I got fed up with all the "bing's and bong's". I also think it gave a warning at mobile speed camera location even if there was not a camera there, which as stated was annoying.
Thu Mar 07 2019 9:20pm |
Any views on whether a dash cam install (hardwired) impacts the warranty (question in the Op) |
Thu Mar 07 2019 9:55pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Thinkware 770 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Mar 08 2019 8:59am |
Thanks for all the above input/comments, seems there's more to this than meets the eye
Fri Mar 08 2019 9:22am |
