![]() | Home > Maintenance & Modifications > Brake Bleed Kits. |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi Guys,
Hi ya,
Just unscrew/slacken the bleed nipple & just wait till fluid is coming out,might take awhile but it works.or you could like you say pump brake peddle up till it goes hard then place something on peddle to keep it down slacken bleed nipple to let air out & repeat till it’s bled. Andy.
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
https://www.ebay.co.uk/itm/HAND-VACUUM-PUM...:rk:1:pf:0
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Hi
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
I use this homemade vacuum extractor made of plastic drain pipe and old fridge compressor. I use this to change engine oil, brake and steering fluids, colant...
