Home > Maintenance & Modifications > Brake Bleed Kits.
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Brake Bleed Kits.
Hi Guys,
I need to bleed a rear caliper on my 2014 Range Rover Sport.
What brake bleed kit for one person to use would you recomend that you have used etc?
Cheers!
Post #576290 Sun Mar 03 2019 6:11pm
Tyrefitter
Can you get someone sat in the car to pump the pedal to do it,,it’s only a 2 minute job if your only bleeding one.Or you could just loosen the nipple & let it gravity bleed,ive done that many times when I’ve been on my own. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #576299 Sun Mar 03 2019 7:55pm
the_big_1
Hi ya,
Only me here. How did you do the gravity bleed?
One way I have read too is to get a pipe, block one end with a bolt etc. Cut a slit in the pipe above the bolt. Submerge in fluid. Then when you press the pedal, it force fluid through the slit but slit closes when pedal released. Was thinking of that but instead of letting pedal up, use a piece of wood to keep pedal down. Lock off the nipple, let the pedal up and then release the nipple and repeat
Post #576304 Sun Mar 03 2019 8:08pm
Tyrefitter
Just unscrew/slacken the bleed nipple & just wait till fluid is coming out,might take awhile but it works.or you could like you say pump brake peddle up till it goes hard then place something on peddle to keep it down slacken bleed nipple to let air out & repeat till it’s bled. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #576321 Mon Mar 04 2019 2:32am
Bardley
Here..
https://www.ebay.co.uk/itm/HAND-VACUUM-PUM...:rk:1:pf:0
These work well. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #576327 Mon Mar 04 2019 7:22am
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
I have this one :- https://www.machinemart.co.uk/p/tool-connection-eezibleed-kit/
Several others on that site.
Post #576337 Mon Mar 04 2019 10:04am
N60613
Bosnia Herzegovina
I use this homemade vacuum extractor made of plastic drain pipe and old fridge compressor. I use this to change engine oil, brake and steering fluids, colant...
check bleading nipels to for rust. I replaced my with Stainless steel.
Bleeding brakes by yourself pay attention not to suck air from empty fluid cylinder. this plastic bottle is great help.
hope this helps
Nino, Thumbs Up RR 2012 4.4 TDV8
Post #576424 Tue Mar 05 2019 11:13am
